6847 Discussions
Problem in dll with intel ipp on different machine.
elangbamjohnson
I've purchased intel ipp and compile sucessfully on vc++ 2005 with pjsip1.0-rc3, I've found all the speech codecs that I want to include. In order to add to my softphone I am using pjsipdll and sucessfully create the dll on my personal machine, the dll works fine with all the speech codecs on my machine and make a test call also, however when I try to run my softphone on different machine with the intell ipp dll it gives runtime error and terminates automatically, surprisingly the same softphone without the intel ipp dll is running on another machine without any problem. I am confusing what the problem is, and where the problem might be.
Any suggestion is appreciated.
Elangbam Johnson
Vladimir_Dudnik
can you build that system in debug mode to try at least detect the module which cause the issue?
Vladimir
