Problem linking video_enc_con in C++ builder.
janlund1967
Hello.
I am trying to build the video_enc_con in C++ Builder (bds2006) but i have some problems when the linking starts.
I have added program filesintelipp5.1ia32lib to the library search path, but i get a bunch of linker errors :
[C++ Warning] basetsd.h(345): W8058 Cannot create pre-compiled header: code in header
[Linker Error] Error: Unresolved external 'ippsFree' referenced from C:IPP_SAMPLEMEDIAAPPLICATIONVIDEO_ENC_CONSRCDEBUG_BUILDMPEG2_PARAMS.OBJ
[Linker Error] Error: Unresolved external 'ippiHuffmanTableFree_32s' referenced from C:IPP_SAMPLEMEDIAAPPLICATIONVIDEO_ENC_CONSRCDEBUG_BUILDENCODER_MPEG2.OBJ
[Linker Error] Error: Unresolved external 'ippsMalloc_8u' referenced from C:IPP_SAMPLEMEDIAAPPLICATIONVIDEO_ENC_CONSRCDEBUG_BUILDMPEG2_PARAMS.OBJ
[Linker Error] Error: Unresolved external 'ippiGetDiff8x4_8u16s_C1' referenced from C:IPP_SAMPLEMEDIAAPPLICATIONVIDEO_ENC_CONSRCDEBUG_BUILDENCODER_MPEG2.OBJ
... and the list continues...
Can someone help please ?
best regards
Jan
Chao_Y_Intel
Hi, Jan
You can not directly link to the Intel IPP static library in the Borland environment.
You need to create a customized Intel IPP DLL based on the functions you used, and linked with the import library created by the Borland IMPLIB utility:
Please the FAQ bellow:
http://www.intel.com/support/performancetools/libraries/ipp/win/ia/sb/CS-010672.htm
Chao
