Problem rotating 32-bit png with alpha channel
tim_c_2
I can do this using OpenCV to load the image file and then the WarpAffine function from the ipp_blur_rotate_sample SDK sample; the alpha channel from the original image is preserved however areas in the new rotated image that were not originally present default to 100% opacity which is not what I want. I would like them to default to transparency but cant see how to do this easily without extra processing ( subsequently I am using ippiAlphaComp_8u_AC4R to composite the rotated image with larger video frames and don't want to them obscure parts of the video ).
I can work round this by my making my images larger and then when compositing specifying a smaller ROI which gets all the important content but doesn't include the opaque new regions but this is not ideal since it requires extra calculation.
- I found out this morning its simply a question of setting the border value argument iWarpAffineLinearInit(...) to a value which has the alpha channel set to zero
Shaojuan_Z_Intel
Hi Tim,
Thanks for letting us know the "trick" to achieving the targeted opacity in rotation. Thanks!
