Problem with FilterBilateralBorder
Sergey_S_2
I tried to use ippiFilterBilateralBorder_32f_C1R and got incorrect results.
Then I have run an example from the manual for ippiFilterBilateralBorder_8u_C1R (copy-paste) but have gotten different, incorrect results too (below).
 1   2   3 123 123 125  54  54
 3   4   5 128 130 130  61  62
 4   5   6 131 132 133  64  65
 6   6   6 132 133 133  66  66
 7   7   6 133 133 132  66  66
 7   6   5 133 132 131  66  65
 6   5   4 132 131 130  65  64
I am using IPP 8.1.0 under 64-bits Win 7 Pro SP-1 and MS Visual Studio Pro 2013.
Ivan_Z_Intel
there is an error in the documentation about ippiFilterBilateral. In example the result is wrong.
Your result is correct.
This bug will be fixed in next version. Many thanks!
If you believe that function ippiFilterBilateralBorder_32f_C1R works incorrect than send the example of code please!
Thanks one more!
Sergey_S_2
Hi Ivan,
Thanks for your quick response.
I will re-check my original problem with ippiFilterBilateralBorder_32f_C1R.
