Software Evaluation question
Louis_P_
I would like to evaluate the speech coding samples of the Intel IPP librairies.
I have downloaded the 30-day evaluation of Parallel Studio XE Composer Edition for Fortran and C++ Linux*. Is this the correct package?
I understand that the speech coding sample is deprecated, however I am confused as there is an entry called Speech Coding Functions (https://software.intel.com/en-us/node/502412) in the  Reference Manual for Intel® Integrated Performance Primitives 8.2 Update 2.
It even gives a link to the  Intel IPP Speech Coding Samples:
The use of the Intel IPP speech coding functions is demonstrated in Intel IPP Samples. See Intel IPP Speech Coding Samples downloadable from http://www.intel.com/cd/software/products/asmo-na/eng/220046.htm.
However, this link does not seem to work.
Is it possible to try the speech coding samples  with an evaluation copy of the Intel® Integrated Performance Primitives?
Thank you,
Louis.
Jonghak_K_Intel
Hi Louis,
 thank you for trying out IPP.
 For installing the deprecated domain, please refer this article : https://software.intel.com/en-us/articles/install-the-additional-domains-for-intel-ipp-82
 and for sample code for deprecated domains use this link : https://software.intel.com/en-us/articles/code-samples-for-intel-integrated-performance-primitives-intel-ipp-library-70 .
 Thank you.
Jonghak_K_Intel
Hi Louis,
 Thank you.
