Problem with ijg80b library
Marco_B_2
Hello everybody.
I'm trying to develop an application that compress fastly images from raw format to JPEG and then sends them over the network to a particular destination server.I've tried the library ijg80b provided with IPP examples. My problem is the fact that while the function to save images to a file works fine, the use of a memory destination does not work correctly and the risulting JPEG image is not correct (some bytes are added inside the image). I'm using IPP 7.1 with an Intel ATOM N270 processor.
Is there a way to have an update of the library? Is it manteined?
Thank you for the attention.
Marco Bna
