- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
ippiMalloc_* allocate a block of memory with each line aligned on a 32 bytes boundary.
So I guess that width*16/8 + 10 is a multiple of 32 in your case. That is width = 11 + x * 32 if I'm not mistaken.
Matthieu
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
ippiMalloc not only aligns the x but also the y axis. If this is a problem for you, of course you can use ippsMalloc or _aligned_malloc from CRT. Then your stride is width*16/8 and you can use this stride also as a parameter to some ippi* functions. Many ippi* functions like color conversion, add, subtract ... will work without 32byte aligned lines.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
HI, Marco.o
Did find a solution, Ithink you must try and go on the advice renegr's given you. With this way, you'll be ok.Sure.
Feel free and try to submit again if no solution.
Nice to have you as new member
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
