Problems building custom so
Nicolas_G_
I am trying to build a custom .so to link my C++ software against but I am having trouble.
Are there clear and detailed instructions to build a custom .so using CMake that I could find somewhere? If not, can someone guide me through the process. I have instructions for a custom dll from IPP version 6 and sample code from the IPP website but I can't make it work.
From what I understand, I need 4 files:
  1. exports.def (or .txt) containing the list of fucntions I need.
  2. funclist.h containing the declarations of the functions from the ipp*.h files.
  3. some sort of .c file (dllmain.c or init.c) to bring everything together. This is where I get lost...
  4. CMakeLists.txt to compile everything.
Are these the only files I need? What are they supposed to contain?
Thank you very much for your help!
Nicolas
Pavel_B_Intel1
Hi Nikolas,
as I understand you would like to build custom shared library on Linux, so I provide instructions and examples for Linux:
1) define export.txt (you can use any filename) file with exact list of IPP functions which will be exported in your library, for example:
EXTERN( ippiGetLibVersion )
EXTERN( ippsGetLibVersion )
EXTERN( ippiMalloc_16s_C1 )
EXTERN( ippiFree )
EXTERN( ippiSet_16s_C1R )
EXTERN( ippiMul_16s_C1RSfs )
VERSION {
      global:
      ippiGetLibVersion;
      ippsGetLibVersion;
      ippiMalloc_16s_C1;
      ippiFree;
      ippiSet_16s_C1R;
      ippiMul_16s_C1RSfs;
      local: *;
2) define _init() function where you should call ippInit() to initialize IPP dispatcher (main.c):
#include "ipp.h"
int _init(void)
   ippInit();
   return 1;
void _fini(void)
3) compile main.c with -fPIC option and build your shared library:
ld -shared export.txt -o libmylib.so main.o $(IPPROOT)/lib/intel64/libippi.a $(IPPROOT)/lib/intel64/libipps.a $(IPPROOT)/lib/intel64/libippcore.a -lc
That all.
Pavel
