Problems with ipp g729 codec.
tcorp1
IPP_G729I.cpp
I try to code/decode wave file with cs-acelp g729 algoritm using IPP. But it doesn't decode previously coded bitstream normally, there is a lot of noise and there is no voice at all.
Maybe someone had the same problem with it and can help me.
I Add main file which runs both encoder and decoder. I took it from uscmanual.pdf.
Thanks a lot, Ron
Naveen_G_Intel
Did you referred to IPP base g729 sample? I can verify with the sample code by providing data file(wave file).
Naveen Gv
