RSA Encryption
Kryten67
I'm trying to find some easy-to-follow RSA key-generation, encryption/decryption examples.
What I've found are
http://software.intel.com/en-us/node/503498
and
http://software.intel.com/en-us/node/503457
Firstly, I'm not sure why (for example)
// Q prime factor
BigNumber    Q("0xC97FB1F027F453F6341233EAAAD1D9353F6C42D08866B1D05A0F2035028B9D86"
                 "9840B41666B42E92EA0DA3B43204B5CFCE3352524D0416A5A441E700AF461503");
This appear to be constants -- I'm assuming that these values are created by the RSA key generation procedure?
I can't get the samples to build as they are on the Intel site (I'm using IPP 8.1 on Windows FYI). I get the following errors:
error C2660: 'ippsPrimeGen' : function does not take 1 arguments
      IppsPrimeState* pPrimeG = ippsPrimeGen(P.BitSize());
and
1>rsa.cpp(83): error C3861: 'deletePrimeGen': identifier not found
      deletePrimeGen(pPrimeG);
Am I using the right samples for 8.1?
Are there better examples available -- I'm trying to find a good example that shows the end-to-end process or creating private/public key, using keys for encyption and decryption...
Any pointers greatly appreciated.
Igor_A_Intel
hi Paul,
  1. “This appear to be constants -- I'm assuming that these values are created by the RSA key generation procedure?”
Definitely RSA parameters were generated by some RSA key generation procedure.
  1. “I get the following errors: error C2660: 'ippsPrimeGen' : function does not take 1 arguments   IppsPrimeState* pPrimeG = ippsPrimeGen(P.BitSize()); “
I see the typo: ippsPrimeGen instead of newPrimeGen
  1. “rsa.cpp(83): error C3861: 'deletePrimeGen': identifier not found    deletePrimeGen(pPrimeG);”
Agree. No deletePrimeGen() propotype. I’ve send an update to the manual - will be available in the next release
  1. “Am I using the right samples for 8.1?”
Samples are working in general.
  1. “I'm trying to find a good example that shows the end-to-end process or creating private/public key, using keys for encyption and decryption...”
Use ippCP manual and try something like the following to generate RSA-1024 (it's just a scheme - haven't tried to compile)
   int factorP_bits = 512;
   int factorP_bits = 1024;
   int rsa_bits = factorP_bits + factorQ_bits;
   // random generator
   IppsPRNGState* pRand = newPRNG();
   // prime generator
   IppsPrimeState* pPrimeG = newPrimeGen(factorP_bits);
   // RSA modulus and public exponent
   BigNumber N(0, BITSIZE_WORD(rsa_bits));
   BigNumber E;
   // private type2 RSA
   int prvSize;
   ippsRSA_GetSizePrivateKeyType2(factorP_bits, factorQ_bits, &prvSize);
   IppsRSAPrivateKeyState* pPrvKey = (IppsRSAPrivateKeyState*)(new Ipp8u [prvSize]);
   ippsRSA_InitPrivateKeyType2(factorP_bits, factorQ_bits, pPrvKey, prvSize);
   // scratch buffer
   int bufSize;
   ippsRSA_GetBufferSizePrivateKey(&bufSize, pPrvKey);
   Ipp8u* pBuffer = new Ipp8u [bufSize];
   // init value of the public exponent
   BigNumber E0(3);
   // generate RSA system
   do {
      sts = ippsRSA_GenerateKeys(E0, N, E, NULL,
                                 pPrvKey,
                                 pBuffer,
                                 50,
                                 pPrimeGen,
                                 ippsPRNGen, pPRNG)
   } while(sts!=ippStsNoErr);
regards, Igor
Igor_A_Intel
hi Paul,
   // random generator
   // prime generator
   BigNumber E;
   int prvSize;
   // scratch buffer
   int bufSize;
   BigNumber E0(3);
   do {
                                 pPrvKey,
                                 pBuffer,
                                 50,
                                 pPrimeGen,
                                 ippsPRNGen, pPRNG)
regards, Igor
Kryten67
Thanks!
bevin_b_
There are several problems in the above approximation.  It would be nice to have a working example posted here, or at least a link to one
Abhinav_S_Intel
IPP Crypto samples are available here:
https://github.com/intel/ipp-crypto/tree/develop/examples
