Read Web URL videos
prashanth34
For one of my application, I need to read the videos from web like from youtube or cnn and process them. But I did not find any software which can allow me to read videos from web. I would like to know whether IPP have any function which can do this task. If yes can anyone give me an example of how to do it? Its bit urgent.
Prashanth.
PaulF_IntelCorp
Hello Prahanth,
The IPP library, and its associated sample files, are designed to help you with the low-level implementation of algorithms that emply vector and matrix math. How you perform I/O to send and receive data is outside the scope of the library's purpose.
There are many free and fee-based applications out there that can capture a streaming video and save it to a file. The IPP library does not do this.
Paul
prashanth34
Thanks Paul. I mean I don't want to save the video to a file. Just like VLC player opens the network stream and plays the stream, I need something like that then I would like to read the frames and do the processing on the individual frames. So, is there any other way to do it?
Prashanth.
PaulF_IntelCorp
Hello Prashanth,
Sorry, but the IPP library does not provide sophisticated I/O functions. It only provides the functions you need once you have captured the stream, for processing the actual video stream. It does not contain features to help capture a stream, that is outside the scope of the library.
Paul
Chao_Y_Intel
Hi Prashanth,
For the video, there are different formats. You need to specify which format of the video you want to decode. The video format IPP can support can be found here: http://software.intel.com/sites/products/collateral/hpc/ipp/ipp_indepth.pdf
If you want to only focus on the Flash Video, currently IPP UMC sample does not include such decoder.
thanks,
Chao
prashanth34
Hi Chao,
Just any video format I mean for example a youtube video which is playing in the background can be read directly by giving just the web url address of it and the video can be played by using IPP library. Is that possible?
Prashanth.
Chao_Y_Intel
Hi Prashanth,
Most likely, you want to decodethe flash videos. IPP does not include the high level sample code for that now.
Chao
