I am observing slightly different results when calling ippsSum_64f with the same numbers but in a differently aligned array; is it a bug or a documented behaviour ?
Thanks !
PS: Here is a simple C program that shows this phenomenon:
#include <stdio.h> #include <stdlib.h> #include <string.h> #include <math.h> #include "ipp.h" #define SIZE 1000 #define NB_TESTS 10 int main (void) { int alignment,test,k; double input1[SIZE], input2[SIZE+1]; for (alignment = 0; alignment < 8; alignment ++) { int failed = 0; for (test = 0; test < NB_TESTS; test ++) { double r1, r2; double *p = (double *) (alignment + (char *)input2); for (k = 0; k < SIZE; k ++) { input1= (double)rand() / (double)RAND_MAX; p = input1 ; } ippsSum_64f(input1, SIZE, &r1); ippsSum_64f(p, SIZE, &r2); if (r1 != r2) { printf("[%d %% 8] diff = %e\n", alignment, r2 - r1); failed ++; } } printf("[%d %% 8] %d / %d tests failed\n", alignment, failed, NB_TESTS); } return 0; }
When the alignment is "0 % 8", ippsSum returns the same result on both inputs but when it's non-zero the test some times succeeds, some times fails (with an error around 1e-13).
Hi Marc,
For floating point computation, there could be small epsilon difference in result, and that is expected for different memory alignment. Here is an article discusses about the variation https://software.intel.com/en-us/articles/getting-reproducible-results-with-intel-mkl. Although the article talks about MKL, the same rule applies to IPP. Hope this helps. Thanks!
Thank you for your reply !
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
