6685 Discussions
Results (of ippsSum) depends on the alignment
Marc_L_
I am observing slightly different results when calling ippsSum_64f with the same numbers but in a differently aligned array; is it a bug or a documented behaviour ?
Thanks !
PS: Here is a simple C program that shows this phenomenon:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "ipp.h"
#define SIZE 1000
#define NB_TESTS 10
int main (void) {
  int alignment,test,k;
  double input1[SIZE], input2[SIZE+1];
  for (alignment = 0; alignment < 8; alignment ++) {
    int failed = 0;
    for (test = 0; test < NB_TESTS; test ++) {
      double r1, r2;
      double *p = (double *) (alignment + (char *)input2);
      for (k = 0; k < SIZE; k ++) {
        input1 =  (double)rand() / (double)RAND_MAX;
        p = input1;
      ippsSum_64f(input1, SIZE, &r1);
      ippsSum_64f(p, SIZE, &r2);
      if (r1 != r2) {
        printf("[%d %% 8] diff = %e\n", alignment, r2 - r1);
        failed ++;
    printf("[%d %% 8] %d / %d tests failed\n", alignment, failed, NB_TESTS);
  return 0;
When the alignment is "0 % 8", ippsSum returns the same result on both inputs but when it's non-zero the test some times succeeds, some times fails (with an error around 1e-13).
Shaojuan_Z_Intel
Hi Marc,
For floating point computation, there could be small epsilon difference in result, and that is expected for different memory alignment. Here is an article discusses about the variation https://software.intel.com/en-us/articles/getting-reproducible-results-with-intel-mkl. Although the article talks about MKL, the same rule applies to IPP. Hope this helps. Thanks!
Marc_L_
Thank you for your reply !
