Resync Markers in MPEG4 Encoder
dierssen
Hi!
I use the Intel IPP mpeg4 encoder (ipp_media samples)to create videos. This worked well, but when I enabledresync markers, the video frames showed artifacts and Quicktime sometimes exits with a buffer overrun. It seems that the Intra DC and AC Prediction for I-VOP and P-VOP is the cause of the problem, but I cannot see yet where the real problem resides. I have set the VideoPacketLenght to 1024 (it is used for a mobile phone application) and data partitioning is switched off. If someone knows more about this problem, please let me know.
Greetings Werner.
dierssen
Hi Nikolay,
I attached my output file. It containsa MPEG-4 Unknown Profile(0), 62.660 secs, 44 kbps, 176x144 @ 14.937759 fps video track and an AMR, 60.100 secs, 13 kbps, 8000 Hz audio track. The strange thing is, that when I switch data partitioning on, the problems are gone. So resync markers AND data partitioningis ok, but resync markers without data partitioning is not. Perhaps there goes something wrong with writing headers to the bitstream? I am pretty new to the codec subject, so it is sometimes a little bit guessing for me...
Greetings Werner.
By the way, I am using the 5.0 IPP samples/library.
Vladimir_Dudnik
something wrong, there is no attached file
dierssen
Sorry, attached the file (see old message).
dierssen
Thanks a lot!
Your solution worked :).
Greetings Werner.
