ScaleFactor!
mickeyhah
Hallo,
I know that my question is a little bit silly but till now I can not understand what happened here?
In file ippiman.pdf page 55, I found this one
The following example shows how the precision can be partially retained by means of scaling.The integer square root operation
ippiSqrt (without scaling) for the input value 2 gives the result equal to 1 instead of 1.414. Scaling of the internally computed output value with the factor scaleFactor = -3 gives the result 11, and permits to restore the more precise value as 11*2^-3=1.375.
I didn't understand the bold line, where does "11" come from? Why do we have 11 but not another number?
Thank you very much for any help.
Best,
mickeyhah
Thank you very much for your reply, I have another question about scaleFactor. There are many functions that have scaleFactor, if I don't want to use it, just set itequal 0. Is it right?
Thank you again
