What is an expected performance of H.264 ?
Maciej_K_
I mean possible encoding/decoding fps on some given hardware, codec profile, resolution for IPP5.2 on Windows ?
Vladimir_Dudnik
you may use IPP media sample to test IPP H.264 codec with your specific data and on your specific platform.
Vladimir
Maciej_K_
Thank you, but I want to compare it with my specific data and my specific platform to verify that everything works ok.
Vladimir_Dudnik
then you need to askthe data for specific video resolution, profile/level or other features and sw/hw platform of your interest. If we can test we can provide you info. As I understand you are interested in decoder performance, correct?
Vladimir
shyaki
I tested H.264 for encoding 1920*1080 HD video. The encoding was only a few frame per second, far from real-time. Here is some info about the test.
Computer: Xeon 3.4 G hyperthreading 4 cpus
H.264 parameters:
/* CommentLine: H.264 Sequence.*/
hd_1920_1080_422.yuv10 /* name of source files */
250 /* number of frames to encode */
1 1 1 /* 1(reserved) , N (# of frames in between I frames), IDR interval. */
0 0 /* Number of B frames between I (or P) and next P, treat B as a reference (only 0 is supported!) */
2 1 4 /* num_ref_frames (1-16), minimum length of list1 for backward prediction (only 1 is supported!), number of slices. */
100 51 /* profile_idc (77-main, 100-high); level_idc (set 0 for automatic selection) (check that num_ref_frames and frame size are in accordance with the level) */
1920 /* horizontal_size */
1080 /* vertical_size */
5 /* frame_rate_code: 4,5 - 30 fps; 1,2 - 24 fps; 3 - 25 fps, 6 - 50 fps; 7,8 - 60 fps; other - 30fps */
2 10 10 /* High profile: chroma_format_idc (0 - monochrom, 1 - 420, 2 - 422), bit_depth_luma [8,12], bit_depth_chroma [8,12] */
0 8 0 0 0 /* High profile: aux_format_idc: [0,3], bit_depth_aux: [8,12], alpha_incr_flag: 0, 1; alpha_opaque_value: [0, 2^(bit_depth_aux + 9) -1]; alpha_transparent_value: [0, 2^(bit_depth_aux + 9) - 1] */
1 26 26 26 50000000 /* RC method(1 - CBR, 2 - AVBR framewise, 3 - constant quant); start qp values for I, P, B slices; bitrate (bits per second) */
3 0 64 64 /* ME method(0 - full search; 1 - classic log; 2 - log; 3 - epzs; 4 - full orthogonal; 5 - log orthogonal; 6 - tts), subblock split, search x,search_y */
0 0 0 /* weighted prediction, weighted biprediction implicit weighted biprediction (not supported!)*/
0 1 /* direct type (0 - temporal 1 - spatial); direct_inference_flag */
0 3 3 /* disable_deblocking_idc: 1-- off, 0 - on, 2 -- on(without crossing slice boundaries); deblocking_filter_alpha, deblocking_filter_beta */
1 0 0 /* High profile: transform_8x8_mode: 0 -- off, 1 - on; 0 -- use standard, 1 -- use default scaling matrices for 8x8 quantization; qpprime_y_zero_tr ansform_bypass_flag: (0, 1) */
1920 /* display_horizontal_size */
1080 /* display_vertical_size */
1 2 /* entropy coding mode (0-cavlc,1-cabac); cabac_init_idc (0,1,2) */
0 /* picture coding type (0 - only FRM, 1 - only FLD , 2 - only AFRM, 3 - pure PicAFF(no MBAFF) 4 PicAFF + MBAFF). Only 0 (FRM) is supported! */
0 sample.log /* log mask and template filename of log-file (0 and "any value" for none) (not supported!) */
