6822 Discussions
Seems ITT task event in user application could not be tracking when on "profile system" selected,
yidu
I'm trying to optimize my application's performance on a FreeBSD system. I've installed VTune 2024.2.0 on my Ubuntu laptop and I'm using remote SSH to analyze the performance. I successfully performed hotspot analysis using hardware event-based sampling.
I created a sample application with ITT API enabled, deployed it to a remote FreeBSD machine, and added the INTEL_LIBITTNOTIFY64 environment variable in the startup script. When I use the "Launch Application" feature with this startup script, everything works fine, and I can see the user task events in the results. However, when I use the "Profile System" feature to instrument and manually run the same script, I can't see these user events at all.
Is this behavior by design, or is there something wrong with my environment?
Gennady_F_Intel
This topic is not relevant to Intel IPP library.
We would recommend you submit this topic to the Intel(R) VTune Profiler and Intel(R) Adviser software Forum follow this link:
https://community.intel.com/t5/Analyzers/bd-p/analyzers
yidu
thanks @Gennady_F_Intel , I have post another question as your suggestion. please help me close this.
