Silent install is broken on Mac
aag
$ /Volumes/m_ipp_2020.1.216/m_ipp_2020.1.216.app/Contents/MacOS/install.sh --user-mode --ignore-cpu --silent silent.cfg.mod
Non-administrative setup is not supported. Please launch the setup program with
elevated privileges.
Is there any way around it?
Adriaan_van_Os
Did you try sudo ?
Adriaan van Os
aag
Defeats the purpose of unattended install and "--user-mode", no?
Adriaan_van_Os
Well, the comment in the install.sh file says for --user-mode
        # run installation under current user privileges
and these current user privileges are apparently not enough to install in (say) /usr/local, unless you manually add sudo.
This is UNIX. Read the UNIX Haters Handbook.
Adriaan van Os
aag
UNIX? You don't say! I thought it was Win95-like, possibly more books are needed!
Now that we got the snark and unhelpful comments out of the way ...
What if I'm not installing to /usr/local? Because there's also PSET_INSTALL_DIR -- which we're using (with a decent degree of success) when running an unattended install of, say, OpenVino. And no need for elevated privileges, either.
Adriaan_van_Os
I don't share the UNIX "security" paranoia, as security is a moral rather than a technical issue, but still the UNIX "security" paranoia dictates that executable code goes into folders that users with normal priviliges cannot access to maliciously alter the code.
The simple way around that for the bad boys, by the way, is to  put up a password dialog box, but please don't tell anybody.
Adriaan van Os
