6845 Discussions
SqrIntegral and RectStdDev --> MultiThreading
willyketch
I use ippiSqrIntegral_8u32f64f_C1R (... ) and ippiRectStdDev_32f_C1R(... ) in order to compute a map of local standard deviation on two processors thanks to IPP OPENMP. So, the results with ippiSqrIntegral_8u32s_C1R and ippiRectStdDev_32s_C1RSfs are very different !!! I don't know if it's due to type of data. In the first case we have Ipp64f* pSqr, and in the second case Ipp32s* pSqr. Please, can you help me to order data Ipp64f so that Ipp64f == Ipp32s, and having the same results?
Example of my code :
Ipp32f *pIntegralImg = ippiMalloc_32f_C1(i_width, i_height, &l_i_StepBytes_1);
Ipp32fc *pIntegralCarreImg = ippiMalloc_32fc_C1(i_width, i_height, &l_i_StepBytes_2);
Ipp64f *pIntegralCarreImg1 = (Ipp64f*)malloc(i_width*i_height*sizeof(Ipp64f));
IppiSize roiSize_2 = {i_width - Block.width , i_height - Block.height};
Ipp32f *pMAP_Local_StdMean = ippiMalloc_32f_C1(roiSize_2.width, roiSize_2.height, &l_i_StepBytes_3);
l_i_status = ippiSqrIntegral_8u32f64f_C1R(puc_img,
i_width,
pIntegralImg,
l_i_StepBytes_1,
pIntegralCarreImg1,
l_i_StepBytes_2,
roiSize,
0,
0);
l_i_status = ippiRectStdDev_32f_C1R (pIntegralImg,
l_i_StepBytes_1,
pIntegralCarreImg1,
l_i_StepBytes_2,
pMAP_Local_StdMean,
l_i_StepBytes_3,
roiSize_2,
Block);
Thanks you very much for your help.
Regardless,
willy
Vladimir_Dudnik
could you please specify what IPP version and what platform do you use?
Vladimir
