Support for AMD
harald85
Hello
I want to implement an user mode program which uses the GSM Codecs from the intel IPP. THe only problem is that it has to run with amd and Intel processors. Is this any problem?
Harald
Vladimir_Dudnik
Hello Harald,
Intel IPP designed to work on any processor which 100% compatible with Intel Architecture. The processor specific code dispatching is based on processor features not on the manufacturer brand name. It means if given processor supports Intel SSE instruction set than IPP will use SSE optimized code branch. You may estimate potential performance of IPP functions on your target processor by running IPP performance system tests which available in IPPtoolsperfsys folder.
Vladimir
