6814 Discussions
The results of ippsCopyLE_1u and ippsCopyBE_1u are same
sun_c_
As the doc says(https://software.intel.com/en-us/node/502043),ippsCopyLE_1u and ippsCopyBE is diffierent.
do a small test used IPP2017
Ipp8u a = 1;//  00000001  high bit->low bit
 Ipp8u aBE = 0, aLE = 0;
 ippsCopyBE_1u(&a, 0, &aBE, 0, 8);
 ippsCopyLE_1u(&a, 0, &aLE, 0, 8);
The result is aBE=1,aLE=1
Should aLE be 128? // 10000000  high bit->low bit
Ivan_Z_Intel
Thanks for your feedback.
The order of bits in source and in destination are the same. So the function results in your example are identical.
You can see different results for such example
ippsCopyBE_1u(&a, 0, &aBE, 0, 7);
 ippsCopyLE_1u(&a, 0, &aLE, 0, 7);
sun_c_
Thanks.The order of bits in source and in destination are the same.
