Threading layer functions
karthi127
I am trying to parallelize a serial code on video working frame by frame where i divide each frame into number of blocks and do the necessary processing .
Now i want to parallelize the part where i process each block of image.
Should i use OpenMP or use Threading layer functions from IPPI documentation?
And can you provide examples on using threading layer functions.
I tried openMP it seemed to do the processing but the output file is not arranged properly.
I am beginner in IPP and OpenMP
Any source for study will be helpful
Thank you
VidyalathaB_Intel
Hi Karthik,
Intel® Integrated Performance Primitives (Intel® IPP) library provides threading layer (TL) functions for image processing. Threading Layer depends on the OpenMP* or Intel® Threading Building Blocks (Intel® TBB) library according to the selected threading type. Please refer: https://software.intel.com/content/www/us/en/develop/documentation/ipp-dev-reference/top/volume-2-image-processing/intel-integrated-performance-primitives-concepts-1/threading-layer-functions.html
The source code and corresponding header files are available in the components_and_examples_<os>.zip archive inside the <ipp directory>/components subdirectory. You can go through the existing samples which are provided under interfaces/tl/examples directory for better understanding of threading layer functions.
Let us know if this helps.
Vidya.
VidyalathaB_Intel
Hi Karthik,
Vidya.
VidyalathaB_Intel
Hi Karthik,
Thanks for accepting as a solution.
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Vidya.
