Tiled rotate with smoothing has bad edges
Evgeniy_Kosmin
ippiRotate gives me different results with single image rotation and tiled one. Tiled result has some artifacts on the edges.
Here is my code:
// Rotate on single image
  IppiRect dstBounds = {0, 0, pResult->GetWidth(), pResult->GetHeight()};
  IppStatus res = ippiRotate_8u_C3R(pSrcPixels, srcSize, stripe.GetStride(), srcBounds, pDstPixels, pResult->GetStride(), dstBounds, _angle, _xShift, _yShift, IPPI_INTER_CUBIC | IPPI_SMOOTH_EDGE);
  if (res < ippStsNoErr)
    EX_THROW(IppException(EX_PARAMS, res));
// Rotate on tiled image
  uint32_t tileSize = 15;
  uint32_t tileCountX = 15;
  uint32_t tileCountY = 15;
  for (uint32_t i = 0; i < tileCountY; i++)
    for (uint32_t j = 0; j < tileCountX; j++)
        IppiRect dstBounds = {i * tileSize, j * tileSize, tileSize, tileSize};
Without IPPI_SMOOTH_EDGE both results are equal.
Please correct me if I’m doing something wrong.
Evgeniy Kosmin
SergeyKostrov
Valued Contributor II
Hi Evgeniy, Some time ago we had a discussion ( please take a look ): Forum Topic: ippiRotate edge effects Web-link: software.intel.com/en-us/forums/topic/344452 and it looks like your problem is similar. Unfortunately, I don't know anything about status of the problem ( is it fixed? is it reproduced? ) and I expect Intel Software Engineers should provide more technical details. Best regards, Sergey
wnag_y_
Gatwick is an excellent area with regard to leasing work place within Tube Ends, Birmingham isn't any lengthier the actual centre from the UNITED KINGDOM because of costly lease and purchasing expenses as well as severe blockage which means the actual transportation systems tend to be match in order to burst open and therefore are battling to handle the present occupants not to mention brand new Safety Handle companies. Leasing work place provides a less dangerous option to the actual large pounds of the long-term home loan.
