Trying to link icpp to gcc
magalhaes_duarte_cor
I'm getting the error
fatal error: ippcp.h: No such file or directory
When trying to link the library to gcc when running the example https://software.intel.com/en-us/ipp-crypto-reference-2019-signing-verification-using-the-elliptic-curve-cryptography-functions-over-a-prime-finite-field.
I'm trying to compile using gcc with the following command:
sudo g++ signverifyV2.cpp -L/opt/intel/compilers_and_libraries_2019.3.199/linux/ippcp/lib/intel64 -L/opt/intel/compilers_and_libraries_2019.3.199/linux/compiler/lib/intel64 -lirc -lsvml -limf -lippcp
Any help would be appreciated!
Abhinav_S_Intel
Your error seems to be related to Intel IPP crypto library. First step would be verify the installation of IPP crypto. Crypto is a separate package from the IPP main package.
If it's not installed you can get the package at GitHub: : https://github.com/intel/ipp-crypto
Sergey_K_Intel
This is a compilation error, not linking issue. It means that compiler, processing the line "#include <ippcp.h>", could not find the required file. The issue is treated using "-I<additional include files search directory>" (capital "i") compiler command line option. Of course, you should have "ippcp.h" somewhere on your system.
