UMC::MPEG2Muxer problem in TS buffer
Deleted_U_Intel
I try to mux mpeg2 transport stream using UMC::MPEG2Muxer. But after analizing in MProble I find permanently buffer overflow. In program stream, muxer always get a buffer underflow but I can fix this problem byself. Can any please check this in your TS streams?
Regards, Artyom.
Vladimir_Dudnik
what version of IPP and sample do you use?
Vladimir
Vladimir_Dudnik
you may want to check the latest IPP 6.0 version where these issues might be fixed.
Vladimir
