I have a existing mp4 file to which I wish to append a few more frames.
What is the file writer parameters method to create a file writer to append data.
For instance, if I create file writer like this:
[cpp]m_fileWriterParams.m_portion_size = 0; vm_string_strcpy(m_fileWriterParams.m_file_name, (wchar_t *)m_inFileName.c_str()); status = m_fileWriter.Init(&m_fileWriterParams);[/cpp]It erases all the data in the current mp4 file. How do I initialize it in "Append" mode?
I searched UMC docs and could not find any simple way. Is this really complicated?
Did you try calling the PutData function?
Thank you for the response!!
No, did not call PutData.
As soon as the call to FileWriter.Init() happens, the data is cleared (it is a valid mp4 file). I think the file is opened in "Write" mode and not "Append" mode. So makes sense.
How do I open it in Append mode.
Not applicable
09-21-2012
02:15 PM
Aditya Kadambi wrote:
I have a existing mp4 file to which I wish to append a few more frames. What is the file writer parameters method to create a file writer to append data. For instance, if I create file writer like this:
