Hi, all!
I want to use EC noise reduction without echo cancellation itself. How can I do this?
Can I use USC_ECNR_Fxns functions to do this job? I found somewhere on this forum
that it works a little different when is used in conjunction with EC (CancelEcho function),
so that less noise is being cancelled if EC NR filter is used separately. Is this true?
Hi Evgeny!
For noise reductionspecifically the USC_ECNR_Fxns could be used or directly EC filtering noise functions as well, as it shown in the ipps manual or the freqdist.c file in the samples:
ippsFilterNoiseDetectModerate_EC_32f64f(sin,rin,&state->sinNoisePwr,&state->dcOffset,&sinNoiseFlag,state->nrSin);
nMode=sinNoiseFlag?ippsNrUpdateAll:ippsNrUpdate;
ippsFilterNoise_EC_32f_I(sout,nMode,state->nr);
The level of noise removed is regulated by the level option in the ippsFilterNoiseLevel_EC_32f()
which could take the following meanings:
ippsNrNone
, ippsNrLow,ippsNrMedium, ippsNormal,ippsNrHigh.
regards,
Ivan
