Use of Least Square Method on IPP
jeremy_74
Hi together,
I'm writing at the moment a Class for Calibrating Cameras with the Tsai Algorithm. Now I have problems to use the IPP for the solution of the overdetermined linear system of equations (maybe the reason is, that school is date back ;-) )
Well I thought I could use one of the two "Least Squares Problem Function" of the IPP. But my structure of equation is:
[A1n A2n A3n A4n A5n A6n A7n] [x1 x2 x3 x4 x5 x6 x7]T = [Bn]
n = 0...Count Of Rows
all Ain and Bn are known an all xi are unknown.
How I have to use the transfer parameters of the ipp functions? Can anybody help me, please?
And - yes I know that I'm bad in mathematic.
jeremy_74
Well I could answer a part of my question by myself.
1. Step:
ippmQRDecomp_m_32f(&A[0], A-Width*4, 4, pBuffer, &AQDR[0], A-Width*4, 4, 7, height);
2. Step:
ippmQRBackSubst_mv_32f(&AQDR[0], A-Width*4, 4, pBuffer, &B[0], 4, &B[0], 4, 7, height);
I think this is the right way for the solution of this overdetermined linear system of equations.
But: In Step 1 there occurs the Error
ippStsDivByZeroErr = Returns an error when the source matrix has an incomplete column rank
Has anyone of you any idear? I'm quite sure about the strides, but this means that the column rank is wrong - what I can not imagine..
jeremy_74
Ok I like to share my new knowledge with you ;-)
In my opinion it seems to be a bug in the IPP or the documentation: it works if I swap srcStride1 and srcStride2 !! I will report this to Intel and don't need any further help. I'm just a little bit confused that I am the first who recognized this bug.
Vladimir_Dudnik
Hello and thanks for sharing your experience here. It would be nice if you can share here the piece of code to show how do you call IPP function, to see if there are any issues with parameters order you mention.
Vladimir
jeremy_74
Here is the piece of code I could share with you:
Ipp32f xdis, ydis;
[bash]//Declaration of the needed matrix:[/bash]
int matrixSize = 7 * m_imagePointX.size();
Ipp32f matrixA[matrixSize];
Ipp32f matrixQDR[matrixSize];
Ipp32f matrixB[7] = {0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0};
Ipp32f matrixC[m_imagePointX.size()];
int t;
std::cerr<<"CameraCalib::ExecuteCalib: "<
[bash]//Filling the Matrix[/bash]
for(int i=0; i {
t = i*7;
xdis = m_dxs * (m_imagePointX - m_cx);
ydis = m_dy * (m_imagePointY - m_cy);
matrixA = ydis * m_imagePointX;
matrixA[t+1] = ydis * m_refPointY;
matrixA[t+2] = ydis * m_refPointZ;
matrixA[t+3] = ydis;
matrixA[t+4] = -1 * xdis * m_refPointX;
matrixA[t+5] = -1 * xdis * m_refPointY;
matrixA[t+6] = -1 * xdis * m_refPointZ;
matrixC = xdis;
std::cerr<<"t="<<<"i="<<<"->"<<<" "<<<:ENDL> }
[bash]//calculation:[/bash]
IppStatus status;
int stride1 = 4*7;
int stride2 = 4;
int matrixHeight = m_imagePointX.size();
Ipp32f buffer[matrixHeight+1];
status = ippmQRDecomp_m_32f(&matrixA[0], stride2, stride1, &buffer[0], &matrixQDR[0], stride1, stride2, 7, matrixHeight);
if (status != ippStsNoErr)
std::cerr<<"ippmQRDecomp_m_32f Error Status:"<<<:ENDL> return IS::CalculationError;
status = ippmQRBackSubst_mv_32f(&matrixQDR[0], stride1, stride2, &buffer[0], &matrixC[0], stride2, &matrixB[0], stride2, 7, matrixHeight);
std::cerr<<"ippmQRBackSubst_mv_32f Error Status:"<<<:ENDL> return IS::CalculationError;
std::cerr<<"Erfolg bei Berechnung:"<<<:ENDL>
