6845 Discussions
Using FFT from Visual Basic 2005 / .NET in general
albusmw
Hello!
I am trying to use the FFT function from the Intel IPP from Visual Basic 2005, but I am missing the description of the FFTSpec function in order to call the FFTInit function correct.
Where can I find the definition (a full-working FFT example code would be best, but also the definition of the strcutrure would be ok ...).
Martin.
Ying_S_Intel
Dear Customer,
You may check the IPP manuals from doc directory for full function descriptions, these manuals are also available online at:
http://www3.intel.com/cd/software/products/asmo-na/eng/346532.htm
1D and 2D FFT functions can be found in Volume 1 and 2 respectively.
In addtion to this, you may check out the sample for VB.NET environment and see how you can use it for specific FFT functions you'd like to use for VB.NET.
Sample list is downloadable from http://www.intel.com/software/products/ipp/samples.htm
Hope it helps.
Ying
