Video frame resizing from QCIF to CIF
myotun
Does any body know how sample codes of IPP work for resizing the video frame (H.264 transcoding from QCIF to CIF) ? I would appreciate if you could give me the pointer for any documentation related to this.
MT
Tamer_Assad
Innovator
Hi Mt,
ippiman.chm is probabily the reference you need; Check the Image Geometry Transforms section, in case you want to resize an image
Or you may search the ippiman.chm for (upsample) if this is what you need to do.
Tamer Assad
I was trying (mistakingly)to mux MP2 video stream into .mp4 file using the UMC:: MP4Muxer.
Multiplexing an MPEG4 encoded video with UMC:: MP4Muxer reulted in a prety playable .mp4 file (thanks to IPP guys).
Regarding the muxin function call sequence, PutData() encapsulates the necessary calls the Lock/UnlocBuffer functions, it works as expected.
I still have the question about the MP4 version, why v1?
Tamer Assad
Tamer_Assad
Innovator
Hi Mt,
Tamer Assad
Tamer Assad
myotun
Thanks Tamer,
I found that IPP H.264 encoder uses ippiResize_8u_C1R() function for resizing the video frames. The usage of this function well documented under ippiman.pdf.
Thanks again for your info.
MT
