Video transcoding
ssingh179
If I write an application for transcoding video (let's say, H.263 -> H.264 ), I can, of course, do a full decode to YUV, and then do a full encode, YUV -> H.264 bitstream.
However, if I wish transcode by only parsing/partially decoding the H.263 bitstream, and then "processing" this partially decoded stream to create a legitimate H.264 bitstream, does IPP provide any in-built support for such operations?
Essentially, the idea is to transcode as efficiently as possible, using IPP.
S
shyaki
Quoting - ssingh179
S
either H.264 or H.263 is an IBP codec which in general involves motion estimation/compesation to remove the temp redundency, and DCT-like transform to remove the spatical redundency. I don't think it is possible to transcode withoutuncompress the source and re-compress it to the new format. At least, 8x8DCT is used in h.263 while 4x4 integer transform is used in h.264. They are fundamentally different.
h.264->mpeg2 may be possible with only syntax translation, but I am not sure.
shyaki
Quoting - shyaki
I mean h.263->mpeg2.
