공지
6814 토론
Where are available codes of Intel® IPP UIC Sample Application – Picnic
Piotr_S_
초급자
979 조회수
From where I can download free sample codes of 'Intel® IPP UIC Sample Application – Picnic' application ?? I'm intrested in usage of 'ippiInpaint_8u' function
On site:
https://software.intel.com/en-us/articles/unified-image-codec-sample-image-inpainting
should be link to free samples but there is nothig what I can download.
Thanks in advance for help
Piotr S.
0 포인트
1 응답
Ying_H_Intel
중재자
979 조회수
Hi Piotr
The   sample is not available as they were legacy for years. You may get from intel registration center for the older version and sample.    https://registrationcenter.intel.com/
As for  the  'ippiInpaint_8u' , you may refer to ipp manual  https://software.intel.com/en-us/articles/intel-integrated-performance-primitives-documentation/  and there is sample ippiPyramidInitAlloc in the manual, you can modify them into a ippiInpait code.
Ying
Example
void UsePyramids(Ipp32f *pSrc, IppiSize srcRoi, int srcStep, Ipp32f *pkernel, int kerSize) {
float rate = 2.0f;
IppiPyramid *gPyr; // pointer to Gaussian pyramid structure
IppiPyramid *lPyr; // pointer to Laplacian pyramid structure
// allocate pyramid structures
ippiPyramidInitAlloc (&gPyr, 1000, srcRoi, rate);
ippiPyramidInitAlloc (&lPyr, 1000, srcRoi, rate);
int i;
IppiPyramidDownState_32f_C1R **gState = (IppiPyramidDownState_32f_C1R**)&(gPyr->pState);
IppiPyramidUpState_32f_C1R **lState = (IppiPyramidUpState_32f_C1R**) &(lPyr->pState);
Ipp32f **gImage = (Ipp32f**)(gPyr->pImage);
Ipp32f **lImage = (Ipp32f**)(lPyr->pImage);
IppiSize *pRoi = gPyr->pRoi;
int *gStep = gPyr->pStep;
int *lStep = lPyr->pStep;
int level = gPyr->level;
Ipp32f *ptr;
int step;
// allocate structures to calculate pyramid layers
ippiPyramidLayerDownInitAlloc_32f_C1R (gState, srcRoi, rate, pkernel,
kerSize, IPPI_INTER_LINEAR);
ippiPyramidLayerUpInitAlloc_32f_C1R (lState, srcRoi, rate, pkernel,
// build Gaussian pyramid with level+1 layers
gImage[0] = pSrc;
gStep[0] = srcStep;
for (i=1; i<=level;i++) {
gImage = ippiMalloc_32f_C1(pRoi.width,pRoi.height,gStep+i);
ippiPyramidLayerDown_32f_C1R (gImage[i-1], gStep[i-1], pRoi[i-1], gImage,
gStep, pRoi, *gState);
// build Laplacian pyramid with level layers
ptr = ippiMalloc_32f_C1(srcRoi.width,srcRoi.height,&step);
for (i=level-1; i>=0; i--) {
lImage = ippiMalloc_32f_C1(pRoi.width,pRoi.height,lStep+i);
ippiPyramidLayerUp_32f_C1R(gImage[i+1], gStep[i+1], pRoi[i+1], ptr, step, pRoi, *lState);
ippiSub_32f_C1R(ptr, step, gImage, gStep, lImage, lStep, pRoi);
0 포인트
응답
