6814 Discussions
Where are available codes of Intel® IPP UIC Sample Application – Picnic
Piotr_S_
From where I can download free sample codes of 'Intel® IPP UIC Sample Application – Picnic' application ?? I'm intrested in usage of 'ippiInpaint_8u' function
On site:
https://software.intel.com/en-us/articles/unified-image-codec-sample-image-inpainting
should be link to free samples but there is nothig what I can download.
Thanks in advance for help
Piotr S.
Ying_H_Intel
Hi Piotr
The   sample is not available as they were legacy for years. You may get from intel registration center for the older version and sample.    https://registrationcenter.intel.com/
As for  the  'ippiInpaint_8u' , you may refer to ipp manual  https://software.intel.com/en-us/articles/intel-integrated-performance-primitives-documentation/  and there is sample ippiPyramidInitAlloc in the manual, you can modify them into a ippiInpait code.
Ying
Example
void UsePyramids(Ipp32f *pSrc, IppiSize srcRoi, int srcStep, Ipp32f *pkernel, int kerSize) {
float rate = 2.0f;
IppiPyramid *gPyr; // pointer to Gaussian pyramid structure
IppiPyramid *lPyr; // pointer to Laplacian pyramid structure
// allocate pyramid structures
ippiPyramidInitAlloc (&gPyr, 1000, srcRoi, rate);
ippiPyramidInitAlloc (&lPyr, 1000, srcRoi, rate);
int i;
IppiPyramidDownState_32f_C1R **gState = (IppiPyramidDownState_32f_C1R**)&(gPyr->pState);
IppiPyramidUpState_32f_C1R **lState = (IppiPyramidUpState_32f_C1R**) &(lPyr->pState);
Ipp32f **gImage = (Ipp32f**)(gPyr->pImage);
Ipp32f **lImage = (Ipp32f**)(lPyr->pImage);
IppiSize *pRoi = gPyr->pRoi;
int *gStep = gPyr->pStep;
int *lStep = lPyr->pStep;
int level = gPyr->level;
Ipp32f *ptr;
int step;
// allocate structures to calculate pyramid layers
ippiPyramidLayerDownInitAlloc_32f_C1R (gState, srcRoi, rate, pkernel,
kerSize, IPPI_INTER_LINEAR);
ippiPyramidLayerUpInitAlloc_32f_C1R (lState, srcRoi, rate, pkernel,
// build Gaussian pyramid with level+1 layers
gImage[0] = pSrc;
gStep[0] = srcStep;
for (i=1; i<=level;i++) {
gImage = ippiMalloc_32f_C1(pRoi.width,pRoi.height,gStep+i);
ippiPyramidLayerDown_32f_C1R (gImage[i-1], gStep[i-1], pRoi[i-1], gImage,
gStep, pRoi, *gState);
// build Laplacian pyramid with level layers
ptr = ippiMalloc_32f_C1(srcRoi.width,srcRoi.height,&step);
for (i=level-1; i>=0; i--) {
lImage = ippiMalloc_32f_C1(pRoi.width,pRoi.height,lStep+i);
ippiPyramidLayerUp_32f_C1R(gImage[i+1], gStep[i+1], pRoi[i+1], ptr, step, pRoi, *lState);
ippiSub_32f_C1R(ptr, step, gImage, gStep, lImage, lStep, pRoi);
