6827 Discussions
Where can I get more details regarding an issue fixed in IPP 7.02
Emmanuel_W_
The following item is mentionned in the list of issue fixed in IPP 7 update 2.
DPD200137548 H.264 Decompression on x64 is significantly slower compared to x32.
It sounds like a serious issue but there is no detail about the fix or situation in which the problem happen.
-Is this a sample fix, a library fix or both ?
-Is this an issue in IPP 6.1 or was this a bug introduced in IPP 7 ?
-Is this an issue with any H.264 stream or only specific profiles ?
Vladimir_Dudnik
this issue was related to the level of optimization for primitive functions. No H.264 sample code changes involved.
Vladimir
Emmanuel_W_
Great thanks, and I suspect that the less optimized code was also in IPP 6.1.
PaulF_IntelCorp
Yes, the optimization problems also existed in the 6.1 code.
Emmanuel_W_
I have run several tests using sample version 6.1 and IPP 6.1 vs 7.02 and can't find any difference in term of speed.
Vladimir_Dudnik
Have you compared performance on IA32 vs Intel64 architectures?
Vladimir
Emmanuel_W_
No I just tested the two versions on 64bits expecting to see an improvment (no 32 bits system on hands).
Emmanuel
Vladimir_Dudnik
Hi Emmanuel,
a lot of factors may affect performance comparison. But for this particular issue we have a confirmation that it was fixed from customer who has intially reported about it. Below are performance data on IPP functions
IPP 6.1IPP 7.0.2
intel64intel64ia32
ippiReconstructLumaIntra8x8_H264High_32s16u_IP1R2.560.3850.574
ippiReconstructChroma422Inter4x4_H264High_32s16u_IP2R0.8970.1580.19
ippiDecodeCAVLCCoeffs_H264_1u32s0.5280.4670.445
ippiReconstructChroma422Intra4x4_H264High_32s16u_IP2R0.140.0790.061
Vladimir
Emmanuel_W_
Thanks Vladimir,
I didn't use 8x8 transform or 422 sampling in my tests so that makes sence ;)
Emmanuel
