6815 Discussions
Why i use ipp5.3 Decode this packet image is divided into two image
yida_123
Hi
I use ipp5.3 decode the packet named 46+47hu.pcap, the video display two same picture .
Actual effect is to display a picture.
yida_123
who can help me?
yida_123
IS THERE ANY good idea
Chao_Y_Intel
Could you provide some more information about your problem here? It can help the users to provide the suggestion more easily?
Which sample code you are using to decode the attached file?
What is the images/video format, etc,
Chao
yida_123
Hello chao
Thanks for your reply!
I used the w_ipp-samples_p_5.3.095\ipp-samples\audio-video-codecs to decode the attached file!
The images/video format is H.264.
Thanks again!
yida
Chao_Y_Intel
Hi Yida,
The file use pcap extension. Is the data in the pcap file package? The UMC simpleplayer does not support such package. Raw H.264 or H.264 in MP4, MPEG TS container can be played with the UMC simpler player application.
btw, IPP 5.3 is a pretty old version. When you do some test, maybe you can try the new IPP 6.1 version or the upcoming IPP 7.0
Chao
yida_123
Hi Chao
Thanks for your replay, i have resoved this problem!
