about jpeg2k compress rate
Ivan_C_
Is there some doc to analyze the compress rate of Jpeg2k ?
I have a source .jp2 file that is about 58KB. I use UIC to transfer it to the .raw file, and the .raw file is about 11.3MB. At last, I use UIC to transfer the .raw file to .jp2 file again. It is surprised that the last .jp2 file is about 1.59MB.
The follow is command arguments:
1, source .jp2 to .raw: uic_transcoder_con -i a.jp2 -o a.raw
2, .raw to .jp2: uic_transcoder_con -i a.raw -r -W 2208 -H 2688 -C gray -P 16s -o aa.jp2 -l 1
Dose anybody know why?? And I upload the file a.jp2.
Sergey_K_Intel
Hi Ivan,
Raw file size is ~11 MB, because 2208 * 2688 * 2 (component depth = 16 bit in source file) = 11,870,208.
Then, "-l 1" equal to "lossless". Lossless image encoding produces lengthy files. Though, even if you set "-l 0" UIC JPEG2000 encoder enforces lossless encoding because the pixel size is 16 bits (I don't know why).
In the "EncodeImage" function you can comment a couple lines:
        //if(image.Precision() > 8)
        //    cmdOpt.lossless = 1;
And, finally, the command line:
uic_transcoder_con -i a.raw -r -W 2208 -H 2688 -C gray -P 16s -o aa.jp2 -l 0 -q 1
(-q 1 means quality = 1%) will give you aa.jp2 of 118 KB. It's bigger than original JP2 file, but something near.
Sergey
