blank image for JPEG XR Encoding
danielwang1971
II try to use UIC::JpegExEncoder to compress a Mono 640x480  8bit image.Encodiong seems OK no error.
But the result image is blank. Quality is 75.   Do you have any idea?
The Bmp and wdp file attached(Rename Camera 1-1.wdp.jpg to Camera 1-1.wdp). And followed is my code:
bool EncodeJPEGXRImage(CIppImage& image,BaseStreamOutput& out,CJPEGXRIppImageInitParam* param,int thread)
  Image                 imageCn;
  Rect                  refgrid;
  Point                 origin;
  RectSize              size;
  ImageDataPtr          dataPtr;
  ImageColorSpec        colorSpec;
  ImageDataOrder        dataOrder;
  ImageSamplingGeometry geometry;
  Ipp32u iChannels;
  Ipp32u iPrecision;
  Ipp32u iFormat;
  Ipp32u iDU;
  Ipp32u bAlphaPresent = 0;
  Ipp16u iTilesUniform[4] = {0};
  Ipp32u iWidth = image.Width();
  Ipp32u iHeight = image.Height();
  InputParams inParams;
  Ipp32u i;
intalpha_mode = 0;
int   aquality = 1;
  JPEGXREncoder encoder;
  iTilesUniform[0] =  0;
  iTilesUniform[1] =  0;
  iTilesUniform[2] =  (iWidth < 16)?0:iWidth/16;
  iTilesUniform[3] =  (iHeight < 16)?0:iHeight/16;
  inParams.iQuality      = (param->Quality* 255)/100;
if(inParams.iQuality < 0) inParams.iQuality = 1;
  aquality = inParams.iQuality;
  inParams.iOverlap      = 0;
  inParams.iBands        = 0;
  inParams.iSampling     = 0;
  inParams.iTrim         = 0;
  inParams.bFrequency    = 0;
  inParams.bCMYKD        = 0;
  inParams.iShift        = -1;
  inParams.bAlphaPlane   = 0;
  inParams.pTilesUniform = iTilesUniform;
if(ExcStatusOk != encoder.Init())
returnfalse;
if(ExcStatusOk != encoder.SetParams(inParams))
returnfalse;
if(ExcStatusOk != encoder.AttachStream(out))
returnfalse;
  iChannels  = image.NChannels();
  iPrecision = image.Precision();
  iFormat    = image.Format();
  iDU        = iPrecision/8;
  size.SetWidth(image.Width());
  size.SetHeight(image.Height());
  origin.SetX(0);
  origin.SetY(0);
  refgrid.SetOrigin(origin);
  refgrid.SetSize(size);
  geometry.SetRefGridRect(refgrid);
  geometry.ReAlloc(iChannels);
  geometry.SetEnumSampling(UIC::S444);
  dataOrder.ReAlloc(Interleaved, iChannels);
  dataOrder.PixelStep()[0] = iChannels * iDU;
  dataOrder.LineStep() [0] = image.Step();
  imageCn.ColorSpec().ReAlloc(iChannels);
  imageCn.ColorSpec().SetEnumColorSpace((ImageEnumColorSpace)image.Color());
  imageCn.ColorSpec().SetColorSpecMethod(Enumerated);
  imageCn.ColorSpec().SetComponentToColorMap(Direct);
for(i = 0; i < iChannels; i++)
if(iPrecision <= 8)
      imageCn.ColorSpec().DataRange().SetAsRange8u(IPP_MAX_8U);
elseif(iPrecision <= 16)
if(iFormat == IF_UNSIGNED)
        imageCn.ColorSpec().DataRange().SetAsRange16u(IPP_MAX_16U);
elseif(iFormat == IF_FIXED)
        imageCn.ColorSpec().DataRange().SetAsRange16s(IPP_MIN_16S, IPP_MAX_16S);
else
        imageCn.ColorSpec().DataRange().SetAsRange16f(IPP_MAX_16U);
else
        imageCn.ColorSpec().DataRange().SetAsRange32u(IPP_MAX_32U);
        imageCn.ColorSpec().DataRange().SetAsRange32s(IPP_MIN_32S, IPP_MAX_32S);
else
        imageCn.ColorSpec().DataRange().SetAsRange32f((Ipp32f)IPP_MIN_32S, (Ipp32f)IPP_MAX_32S);
  dataPtr.p8u = image;
  imageCn.Buffer().Attach(&dataPtr, dataOrder, geometry);
if(ExcStatusOk != encoder.AttachImage(imageCn))
returnfalse;
if(ExcStatusOk != encoder.WriteFileHeader(alpha_mode))
returnfalse;
// Planar alpha support
switch(image.Color())
caseRGBA:
caseBGRA:
caseRGBAP:
caseBGRAP:
caseCMYKA:
    bAlphaPresent = 1;
break;
if(bAlphaPresent && alpha_mode == 1)
    CIppImage imagePrimary;
    CIppImage imageAlpha;
    IppiSize  iROI = {image.Width(), image.Height()};
    Ipp8u*    pData = image;
    Ipp8u*    pDataPr;
    Ipp8u*    pDataAl;
    Ipp32u    iStep = image.Step();
    Ipp32u    iPStep, iAStep;
    Ipp32u    i, j;
if(0 != imagePrimary.Alloc(image.Width(), image.Height(), iChannels - 1, iPrecision, 1))
returnfalse;
if(0 != imageAlpha.Alloc(image.Width(), image.Height(), 1, iPrecision, 1))
returnfalse;
    pDataPr = imagePrimary;
    iPStep  = imagePrimary.Step();
    pDataAl = imageAlpha;
    iAStep  = imageAlpha.Step();
if(iPrecision == 8)
if(image.Color() == IC_CMYKA)
for(i = 0; i < iHeight; i++)
          Ipp8u* pSrc = pData + iStep * i;
          Ipp8u* pDstPr = pDataPr + iPStep * i;
          Ipp8u* pDstAl = pDataAl + iAStep * i;
for(j = 0; j < iWidth; j++, pSrc += 5, pDstPr += 4, pDstAl++)
            pDstPr[0] = pSrc[0];
            pDstPr[1] = pSrc[1];
            pDstPr[2] = pSrc[2];
            pDstPr[3] = pSrc[3];
            pDstAl[0] = pSrc[4];
else
        ippiCopy_8u_AC4C3R(pData, iStep, pDataPr, iPStep, iROI);
        ippiCopy_8u_C4C1R(pData + 3, iStep, pDataAl, iAStep, iROI);
elseif(iPrecision == 16)
          Ipp16u* pSrc = (Ipp16u*)(pData + iStep * i);
          Ipp16u* pDstPr = (Ipp16u*)(pDataPr + iPStep * i);
          Ipp16u* pDstAl = (Ipp16u*)(pDataAl + iAStep * i);
else
        ippiCopy_16s_AC4C3R((Ipp16s*)pData, iStep, (Ipp16s*)pDataPr, iPStep, iROI);
        ippiCopy_16s_C4C1R((Ipp16s*)pData + 3, iStep, (Ipp16s*)pDataAl, iAStep, iROI);
else
      ippiCopy_32s_AC4C3R((Ipp32s*)pData, iStep, (Ipp32s*)pDataPr, iPStep, iROI);
      ippiCopy_32s_C4C1R((Ipp32s*)pData + 3, iStep, (Ipp32s*)pDataAl, iAStep, iROI);
    geometry.ReAlloc(iChannels - 1);
    dataOrder.ReAlloc(Interleaved, iChannels - 1);
    dataOrder.PixelStep()[0] = (iChannels - 1) * iDU;
    dataOrder.LineStep() [0] = iPStep;
switch(imageCn.ColorSpec().EnumColorSpace())
caseBGRA:  imageCn.ColorSpec().SetEnumColorSpace(BGR); break;
caseRGBA:  imageCn.ColorSpec().SetEnumColorSpace(RGB); break;
caseBGRAP: imageCn.ColorSpec().SetEnumColorSpace(BGR); break;
caseRGBAP: imageCn.ColorSpec().SetEnumColorSpace(RGB); break;
caseCMYKA: imageCn.ColorSpec().SetEnumColorSpace(CMYK);break;
default:
returnfalse;
    dataPtr.p8u = pDataPr;
returnfalse;
if(ExcStatusOk != encoder.WriteHeader())
returnfalse;
if(ExcStatusOk != encoder.WriteData())
returnfalse;
if(ExcStatusOk != encoder.FreeData())
returnfalse;
    geometry.ReAlloc(1);
    dataOrder.ReAlloc(Interleaved, 1);
    dataOrder.PixelStep()[0] = iDU;
    dataOrder.LineStep() [0] = iAStep;
    imageCn.ColorSpec().SetEnumColorSpace(Grayscale);
    dataPtr.p8u = pDataAl;
    inParams.iQuality    = aquality;
    inParams.bAlphaPlane = 1;
returnfalse;
returnfalse;
returnfalse;
returnfalse;
returnfalse;
else
returnfalse;
returnfalse;
returnfalse;
returntrue;
Chao_Y_Intel
Hello, The attached input bmp file looks corrupted, and cannot open from here. Could you have a check? Thanks, Chao
danielwang1971
OK,Please try again. Thanks
danielwang1971
Hi, I found problem:amount of tiles per rows and columns can't be 0. So the fix is: iTilesUniform[0] = 1; iTilesUniform[1] = 1; Thanks.
