building problem about ipp sample for PCA
walkdeath
I'm woking on the PXA 270 board.
I've downloaded the ipp sample for PCA and installed the ipp5.0 for PCA.
But when I build the mpeg4_encoder sample application, error occur as follows
/Liod/arm-linux/bin/../lib/gcc-lib/arm-linux/3.3.2/../../../../arm-linux/bin/ld: ERROR: ./build/obj/mp4dblck.o uses FPA instructions, whereas build/bin/mpeg4dec does not
File format not recognized: failed to merge target specific data of file ./build/obj/mp4dblck.o
I use the GNU/arm-linux toolchain instead of the MontaVista toolchain to build this application.
Is there something wrong with the toolchain?
Vladimir_Dudnik
yes, according release notes, IPP v5.0 for PCA on Linux supports only Montavista tool chain.
Vladimir
walkdeath
CFLAGS=-O3 -Wall -mcpu=xscale -mtune=xscale -msoft-float -fPIC
CXXFLAGS=-O3 -Wall -mcpu=xscale -mtune=xscale -msoft-float -fPIC
These are the GNU build option in the makefile of the ipp sample. I omitted the -msoft-float option and build again. It could be built successfully. But still need to verify that the sample work work well on the board.
What are these flags used for? Do they play an importang role? And could they be omitted?
Vladimir_Dudnik
According IPP release notes we support only Montavista toolchain. It means we did not build or test or supportlibraries with other toolchains.
Vladimir
