As the first point, do you know that IPP v4.0 is available now? Why do you use the old version?
Vladimir
- would you rush to install the latest code, if the last time you tried the "latest" code, it ran slower?
- does the latest version come with upgraded documentation that would explain better how to use the features?
Personally, when I first used the NSP, I found the documentation to be excellent. I find the IPP documentation average, in lacking in many areas.
But I digress - do you have any advice or answers to my original questions?
Thanks in advance
We continuously improve functionality and performance of IPP libraries. So, I hope the new version, is always better than the old one. At least we alwayswork to make it happen. I willlook what examples for FIR filters we have and return back.
By the way, what processor do you use to run your code?
Vladimir
Thanks and I understand your point.
The way I figure is that if I can run these experiments, they will work in the new version as well, and I can properly benchmark the performance increases.
We use a variety of Intel processors in our products. Previously, we used an 866 MHz Pentium III (where I could get about 1 GFLOP of performance with the NSP)
We now use a 2.53 GHz Pentium 4.
I have compared NSP and IPP on both processors.
Do you have any ideas how much faster fixed point filters (like the 32 bit coefficient, 16 bit data) would run compared to floating point on this processor? Also, how much faster the direct form might run?
Vladimir
