cannot link
Filip_Krolupper
I get this error message:
>Deconvolution.obj : error LNK2019: unresolved external symbol _ippiFFTInv_PackToR_32f_C1IR referenced in function "signed char __cdecl MyIppBasedCorrelation(float *,float *,float *,unsigned int,unsigned int,unsigned char *,int,struct FFT2DSpec_R_32f *)" (?MyIppBasedCorrelation@@YACPAM00IIPAEHPAUFFT2DSpec_R_32f@@@Z)
and many others linker error.
This I get when compiling 32 bits my own dll library. When compiling 64 bits everything goes well. The next strange thing is that when I use the same code building standalone application 32 adn 64 bits works both flawlesly. I checked compiler settings, paths hundred times and nearly ready to go to my shrink.
any ideas?
thanks
Filip
Sergey_K_Intel
Filip,
Look how IPP functions are declared. Let's take a function from IPPI
IPPAPI( Ipp8u*, ippiMalloc_8u_C1, ( int widthPixels, int heightPixels, int* pStepBytes ) )
How IPPAPI is defined?
[cpp]#if !defined( IPPAPI ) #if defined( IPP_W32DLL ) && (defined( _WIN32 ) || defined( _WIN64 )) #if defined( _MSC_VER ) || defined( __ICL ) #define IPPAPI( type,name,arg ) __declspec(dllimport) type __STDCALL name arg; #else #define IPPAPI( type,name,arg ) type __STDCALL name arg; #endif #else #define IPPAPI( type,name,arg ) type __STDCALL name arg; #endif #endif [/cpp]
The line 9 aboveis the definition which must work in your case if you don't use IPP DLLs. And, the last, how __STDCALL is defined?
[cpp]#if defined( _WIN32 ) || defined ( _WIN64 ) #define __STDCALL __stdcall #define __CDECL __cdecl #define __INT64 __int64 #define __UINT64 unsigned __int64 #else #define __STDCALL #define __CDECL #define __INT64 long long #define __UINT64 unsigned long long #endif [/cpp]
So, all you need is to make sure _WIN32 or _WIN64 is defined. This must be done by MS compiler automatically(this is one of pre-defined macros, I believe even for VS2005 compiler). _WIN32 is defined for both x86/AMD64 platforms. _WIN64 for AMD64 building platform only.
Don't use _WIN32WCE unless you build for Windows CE )). BTW, you can use /E compilation option to get preprocessed file in the form it gets to compiler after all #ifdef parsed. If you see "#define __STDCALL", this will mean you have missed correct definition.
Good luck,
Sergey
Gennady_F_Intel
that's really strange, have you checked dependencis 32 version of your dll from 32 bit's version of ippi, ippcore and etc..?
Filip_Krolupper
Well, I'm using ippi functions so I tried to add as input to the linker ippi.lib ippcore.lib .... no success. As the time goes I tried to add all others libs. Then I suspected the system that it uses wrong path, because of some stupid setting that I'm not able determine. So I deleted all input linker settings and copied right libs to my place and told the linker to use it from the new place. Again no success. I tried to reinstall IPP, I checked system paths. Btw static linkage doesn't work as well. Dont know what to do now.
I suspect there can be some preprocessor setting, that is wrong, but not sure about it. Anyway this thing drives me crazy, because I wanted to release my app last week. The worst thing is, that I know that IPP works great in my regular work - we use it every day, but my own installation sucks. This is a clear proof, that there is something wrong between my chair and my keyboard ;-)
Filip
SergeyKostrov
Valued Contributor II
Hi Filip,
Here are a couple of things to consider:
- Did you try to compile the application on a different computer?
- Did you try to compare your IPP installation withIPP installation on a different computer?
- How many IPPinstallations do you have on your computer?
- Did you check SET and PATH environment variables?
- Did you check a Visual Studio's options?
'Main Menu -> Tools -> Options -> Project and Solutions -> VC++ Directories -> Include Files & Library Files'
- Would you be able to create a simple reproducer of the link error LNK2019?
Sergey
Sergey_K_Intel
Hi Filip,
In fact the name of this function in the library (mangled name) is "_ippiFFTInv_PackToR_32f_C1IR@16". This is how the function names stored in libraries.
Usually the absence of "@XX" suffix means, that corresponding function declaration (prototype) doesn't get MS "__stdcall" attribute. Look at the compilation stage warnings, try to find out where you missed correct function declaration.
Sergey
Filip_Krolupper
I tried today link the solution on 2 different workstations (different installation of IPP), but got the same result. Linker error.
Sergey, thanks very much. In fact I tried to check ippi.lib file and I found out the same thing as you(I mean the suffix @xx is missing, but I'm not that familiar with compilers so I had no idea what does it mean). In this time I dont know how to tell VS 2005 compiler to use _stdcall atribubute for these functions. Will google it a little, and I'll hopefully solve it somehow.
regards
Filip
SergeyKostrov
...I checked compiler settings,...
Did you check Linker settings? This is a Linker error and it is not related to a "wrong" declaration of the
IPP function 'ippiFFTInv_PackToR_32f_C1IR'.
As you stated you managed to compile and linka 64-bit configuration. Then, for a 32-bitconfiguration
compilation was successful, but it fails to link IPP libraries.
A Linker error:
means thatsome IPP library from Image Processing domain is not included for a32-bit configuration.
Sergey
Filip_Krolupper
Sergey Kostrov: yes, I checked even the linker. In VS are linker and compiler settings in the same window ;-)
Filip_Krolupper
I feel that we are very close. If I change code generation settings "Calling convention" from _cdecl to _stdcall the library is linked without error. The problem is that I need to use _cdecl calling convention because my DLL is PS plugin in fact. PS cant work with _stdcall library, it crashes. As I said before, 64 bits version works well as PS plugin, it links without error for _cdecl calling convention. Have to point out that I use VS2005.
Filip
Filip_Krolupper
Ehm, little bit confused. Haven't changed anything in 64 bits and it just began to report the same error. Humpf :-(
Filip_Krolupper
Cool, total chaos ;-) I added _WIN32WCE to preprocessor and 32 bit works, but 64 bit doesn't. One more day and I'll forget this mess and will return to my own libraries ;-)
SergeyKostrov
[SergeyK] Agree.It looks like a"surprize" from Microsoft.Did you add that macroin a source file,
or in a project settings? You can add that macro for a32-bit configuration only in a
project settings for'Preprocessor '
Filip_Krolupper
I did it in project settings - I checked ippi.h and _WIN32WCE causes undef of __stdcall.
SergeyKostrov
I use _WIN32WCE macro for Embedded platforms andI couldn't imaging that it couldaffect calling conversions in IPP.
So, is that a bug or a feature of IPP? What do you think?
Sergey
Filip_Krolupper
I dont think so. I use IPP in my regular work every day and it works. Its some mess in my code. Unfortunatelly I have no idea how to fix it to use IPP. Will give a try one more day. If I fail, I'll leave it.
regards
Filip
Sergey_K_Intel
Filip,
Good luck,
Sergey
Filip_Krolupper
Hi guys, problem solved. I use some other library where was defined __stdcall as an empty string. When I deleted that definition, it starts to work suddently. Guys, how I hate these kind of problems ;-)
thank you all
Filip
Ying_H_Intel
How classical problem! thanks for the sharing.
Add some relatedinformation from Intel Compiler documentation,
Naming Conventions inC/C++
C
cdecl (default)
name (Linux OS)
_name (Windows OS)
_name (Mac OS X)
Mixed case preserved
C (Windows OS only)
__stdcall
_name@n
C++
Default
name@@decoration (Linux OS)
_name@@decoration (Windows OS)
__decorationnamedecoration (Mac OS X)
In the preceding table:
  • The leading underscore (such as _name) is used on Windows operating systems based on IA-32 architecture only.
  • @n represents the stack space, in decimal notation, occupied by parameters on Windows operating systems based on IA-32 architecture only.
For example, assume a function is declared in C as:
  extern int __stdcall Sum_Up( int a, int b, int c );
Each integer occupies 4 bytes, so the symbol name placed in the .OBJ file on systems based on IA-32 architecture is:
  _Sum_Up@12
On systems based on Intel 64 architecture, the symbol name placed in the .OBJ file is:
  Sum_Up
Ying H
Filip_Krolupper
Thank you guys again. I got it. Unfortunatelly I found another problem, which is in IPPI fourier transform implementation. So count with me:
1)setup size increase +70%
2)linking problems (4 days)
3)AMD processor issues
4)Ipp FT problem
.... and the overal speedup is about 20%.
in other words, I quit, IPP means for me more problems than benefits.
thank you again and peace :-)
Filip
SergeyKostrov
...in other words, I quit, IPP means for me more problems than benefits...
I'm really sorry to hear that. What are you going to use instead?
Sergey
