compatibility question
franson
I am considering using your performance library but have such question:
when I build my application with the the library on my machine,
1) will the application run on other machines with different type of intel processors?
2) or shall I build different application for each possiable processors (for best performance)?
3) can the application run on an AMD machine?
thanks for the information.
franson
BTW:
the term "build application" means the process ofcompilingthe souce and link to generateexecutive file.
the term "application" means the executive file (.exe)
Vladimir_Dudnik
Recommended reading is here
Building a Windows* Application Using Intel IPP
You should not build different applications for each Intel processors, see dispatching of cpu-specific code topic in IPP documentation
IPP can work on any processor which is 100% compatible with Intel Architecture.
Vladimir
