compiling MP3 decoder
schakka
I'm novice to both IPP and linux. I'm using IPP5.1 and I'm trying to compile MP3 decoder and its generate "libmp3_dec.a" file. I'm trying to use a sample application "audio_codec_con" provided in IPP. This application looks for "libmp3_dec.so" file. I need to know how to generate "libmp3_dec.so" from the given makefile.
Ram
Vladimir_Dudnik
Hello, I would suggest you to strictly follow instruction in IPP sample's readme.htm file to build it, especially if you are novice in both IPP and Linux.
If you use IPP media sample build procedure correctly it will build all necessary part including audio_codec_con executable for you
Vladimir
