Hi, I am building an application which consists of an mpeg4 encoder and an mpeg4 decoder.
The encoder class and the decoder class themselves compile ok.
BUT at one point in the code, I have to include umc_mpeg4_video_decoder.h and umc_mpeg4_video_encoder.h in the header file of my encoder+decoder class.
After that, compiling the application fails due to a lot of redefinitions:
(ippvideoencodermpeg4.hpp gets included by the encoder and mp4.h gets included by the decoder)
...ippmediacodecmpeg4_decincludemp4.h(233) : error C2365: 'MP4_VISUAL_OBJECT_TYPE_VIDEO' : redefinition; previous definition was a 'enumerator'
...ippmediacodecmpeg4_encincludeippvideoencodermpeg4.hpp(60) : see declaration of 'MP4_VISUAL_OBJECT_TYPE_VIDEO'
Some of those problems can easily be eliminated by commenting out the secondary definitions, because they are exactly the same.
But the following definitions are in fact different, and I can't just get rid of the dupes.
...ippmediacodecmpeg4_decincludemp4.h(495) : error C2371: 'mp4_VideoObjectPlane' : redefinition; different basic types
...ippmediacodecmpeg4_encincludeippvideoencodermpeg4.hpp(174) : see declaration of 'mp4_VideoObjectPlane'
Btw.: Building under WinXp, IA32, Microsoft Visual C++ .NET 2003
What can I do to compile an encoder and a decoder in the same application ?
Thanks for any suggestions...
you are right, we have such restriction in MPEG4 part of media sample. We will fix that in the next release. As a workaround you can use C++ namespace to distiguish similar definitions, instead of commenting them out.
Vladimir
