6814 Discussions
convert from jpeg to bmp, image flipped vertically
awadb
I am using ipp to decode a jpeg to bmp, but the resulted image is flipped vertically. I don't know why this is happening, any ideas?
Vladimir_Dudnik
JPEG keeps images in natural order where as BMP usually uses bottom-left order (means first scan line of image is most bottom line in BMP file). You can take a look on JPEGView IPP sample to see how to display BMP file correctly
Vladimir
awadb
When I build the jpegview sample, I get unresolved externals, could you tell what lib I need to link to please
jpgview error LNK2019: unresolved external symbol _ippiMirror_8u_AC4IR@20 referenced in function "void __cdecl RevertScanLinesOrder(unsigned char *,int,int,int,int)" (?RevertScanLinesOrder@@YAXPAEHHHH@Z)
jpgview error LNK2019: unresolved external symbol _ippiMirror_8u_C3IR@20 referenced in function "void __cdecl RevertScanLinesOrder(unsigned char *,int,int,int,int)" (?RevertScanLinesOrder@@YAXPAEHHHH@Z)
jpgview error LNK2019: unresolved external symbol _ippiMirror_8u_C1IR@20 referenced in function "void __cdecl RevertScanLinesOrder(unsigned char *,int,int,int,int)" (?RevertScanLinesOrder@@YAXPAEHHHH@Z)
jpgview error LNK2019: unresolved external symbol "public: virtual __thiscall CJPEGEncoder::~CJPEGEncoder(void)" (??1CJPEGEncoder@@UAE@XZ) referenced in function "protected: int __thiscall CJPGViewDoc::SaveAsJPEG(char const *)" (?SaveAsJPEG@CJPGViewDoc@@IAEHPBD@Z)
jpgview error LNK2019: unresolved external symbol "public: enum _JPEG_ERROR __thiscall CJPEGEncoder::WriteWholeImage(unsigned char *,int *)" (?WriteWholeImage@CJPEGEncoder@@QAE?AW4_JPEG_ERROR@@PAEPAH@Z) referenced in function "protected: int __thiscall CJPGViewDoc::SaveAsJPEG(char const *)" (?SaveAsJPEG@CJPGViewDoc@@IAEHPBD@Z)
jpgview error LNK2019: unresolved external symbol "public: void __thiscall CJPEGEncoder::SetDestination(int,enum _JPEG_SAMPLING,enum _JPEG_COLOR,int,int)" (?SetDestination@CJPEGEncoder@@QAEXHW4_JPEG_SAMPLING@@W4_JPEG_COLOR@@HH@Z) referenced in function "protected: int __thiscall CJPGViewDoc::SaveAsJPEG(char const *)" (?SaveAsJPEG@CJPGViewDoc@@IAEHPBD@Z)
jpgview error LNK2019: unresolved external symbol "public: void __thiscall CJPEGEncoder::SetSource(unsigned char *,int,int,int,int,enum _JPEG_COLOR)" (?SetSource@CJPEGEncoder@@QAEXPAEHHHHW4_JPEG_COLOR@@@Z) referenced in function "protected: int __thiscall CJPGViewDoc::SaveAsJPEG(char const *)" (?SaveAsJPEG@CJPGViewDoc@@IAEHPBD@Z)
jpgview error LNK2019: unresolved external symbol "public: __thiscall CJPEGEncoder::CJPEGEncoder(void)" (??0CJPEGEncoder@@QAE@XZ) referenced in function "protected: int __thiscall CJPGViewDoc::SaveAsJPEG(char const *)" (?SaveAsJPEG@CJPGViewDoc@@IAEHPBD@Z)
jpgview error LNK2019: unresolved exte rnal symbol _ippiDecodeHuffmanStateFree_JPEG_8u@4 referenced in function "public: enum _JPEG_ERROR __thiscall CJPEGDecoder::Clean(void)" (?Clean@CJPEGDecoder@@QAE?AW4_JPEG_ERROR@@XZ)
jpgview error LNK2019: unresolved external symbol _ippiDecodeHuffmanStateInit_JPEG_8u@4 referenced in function "public: enum _JPEG_ERROR __thiscall CJPEGDecoder::ProcessRestart(void)" (?
Vladimir_Dudnik
I recommend you to read readme.htm "How to build" section and follow these steps.
Vladimir
awadb
Believe me I read your readme.htm on how to build the sample. Unless I am missing something, I don't know where IntelIPP41ia32_itanium directory is
Also, I already setup the sample project in vc7.0, but I don't know what libraries requird to resolve the function calls. Do I need to download something else
  • Set up your build environment by creating an environment variable named IPPROOT that points to the root directory of your Intel IPP installation. For example: C:Program FilesIntelIPP41ia32_itanium
      Vladimir_Dudnik
      Of course, you need to install IPP itself to compile IPP samples.
      Note, by default, IPP install path on Windows for IA32 is C:Program FilesIntelIPP41. Could you please check if you have IPP installed on your system?
      In any case, to link JPEGView sample you need ippcore, ipps, ippi and ipps libraries
      Vladimir
