crash with ippiRemap_8u_C1R when size is 32*32
zy9
running the ippiRemap_8u_C1R using the example of 4 by 4 is ok, but when increase the size to 16 by 16 and many other size above 16*16, the function crash. my code like
IppiSize size = { 16, 16 };
IppiRect srcRect1 = { 0, 0, 16, 16 };
Ipp8u src[16*16] =
0, 1, 2, 3, 4, 5, 6, 7,8, 9, 0, 1,2, 3, 4, 5,
Ipp8u dst[16*16];
Ipp32f pxMap1[16*16] = {
0, 1, 2, 3, 0, 1, 2, 0, 0, 1, 0, 0,0, 1, 2, 3,
Ipp32f pyMap1[16*16] = {
0, 0, 0, 0,1, 1, 1, 0,2, 2, 0, 0,3, 3, 3, 3,
}; // some order of pixels coordinates to write
ippiRemap_8u_C1R ( src, size, 16, srcRect1, pxMap1, 16, pyMap1, 16, dst, 16,
size, IPPI_INTER_NN);
any thing wrong ?
have tried many other size, with setting all 0 to xmap....
thanks
Gennady_F_Intel
Quoting - zy9
Ipp8u src[16*16] =
Ipp8u dst[16*16];
any thing wrong ?
thanks
What IPP version you are using?
What would be if you use other interpolation mode?
--Gennady
zy9
--Gennady
have tried both 5.0 and 6.1.1.035.
I noticed, ippiRemap_8u_C1R xmapstep param, in the given example, it's 4*4 =16, and the result is right, but in the ippdemo runremap.cpp, I run a debug mode, this xmapstep=imagwidth*4, just confused about the parameter and the crash.
zy9
Quoting - zy9
got the answer, the pXmapStep should equal to imageWidth*sizeof(Ipp32f), Ipp32f size is 4, so the example of 4by4 given the step 16, actually is 4*sizeof(Ipp32f), not the the height.
thanks
