cryptography:ippsECCPComparePoint misprint
achrzesz2
Hi
In ipp 6.1.0.038 (64) the function ippsECCPComparePoint returns:
Points are equial
A Chrzeszczyk
Vladimir_Dudnik
what do you actually mean? According function description it is one of the valid function results..
ECCPComparePoint
Compares two points on the elliptic curve defined over GF(p).
Syntax
IppStatus ippsECCPComparePoint(const IppsECCPPoint* pP, const IppsECCPPoint* pQ, IppECResult* pResult, IppsECCPState* pECC);
Parameters
pP
Pointer to the elliptic curve point P.
pQ
Pointer to the elliptic curve point Q.
pResult
Pointer to the comparison result of two points: P and Q.
pECC
Pointer to the context of the elliptic cryptosystem.
Description
The function compares two points P and Q on the elliptic curve defined over a prime finite field GF(p) and allocates the comparison result in accordance with the pointer pResult.
The elliptic curve domain parameters must be hitherto defined by one of the functions: ippsECCPSet or ippsECCPSetStd.
The comparison result of two points P and Q can take one of the following values:
ippECPointIsEqual
Points P and Q are equal.
ippECPointIsNotEqual
Points P and Q are different.
Return Values
ippStsNoErr
Indicates no error. Any other value indicates an error or warning.
ippStsNullPtrErr
Indicates an error condition if any of the specified pointers is NULL.
ippStsContextMatchErr
Indicates an error condition if one of the contexts pointed by pP or pECC is not valid.
achrzesz2
the mentioned funtion should return : Points are equal
and returns: Points are ***equial***
It is not essential but needs needs improvement.
A Chrzeszczyk
achrzesz2
Quoting - achrzesz2
A Chrzeszczyk
I haven't mentioned that I'm using Linux 64bit version (6.1.0.038).
A Chrzeszczyk
Vladimir_Dudnik
I see, thank a lot for catching this, we will correct message in the next nearest update.
Vladimir
