6831 Discussions
does ippi imalloc creates a whole 32 bits for 1 color (channel ?) for each pixel ?
mh_de_ruiter
i cannot see the comparing functions i need for a normal 24 bits (or 32 bits with or without alpha) bitmap
does C3 means there are 3 different bitmaps ? one of each color ?
or is C3 just like the 3 color bytes like a normal bitmap
i just can't find any documents about the subject..
the whole manual is ment to be as-if i know how ippi implements the C3 compared to the C1 etc.
how can i use ippi in combination with normal straight api's of which i normally create a bitmap of ?
friendly regards,
Menno
Vladimir_Dudnik
Hi, please take a look on IPP samples, especially those of them which works with images, for exampleImage and JPEG samples.
Vladimir
mh_de_ruiter
Ok, i will quit with Clarion ;-)
and continue to develope with visual studio
i've had it with Clarion ...
Menno de Ruiter
