g.729 and g.723.1 lost frame example
Arkadi
In IPP 5.2 speech coding sample there is the following fragment of code that performs PLC:
#define G729_SPEECH_FRAME 80
Ipp16s LostFrame[G729_SPEECH_FRAME]={ 0 };
apiG729Decode(DecObj,(const Ipp8u*)LostFrame,(-1),(Ipp16s*)out->pBuffer);
Why LostFrame array is 160 bytes long? Should it be the size of g.729 frame, ie. 10 bytes?
If the decoder is keeping some state in LostFrame array, should it be allocated per-channel?
If no state is kept - in fact I can't see src parameter is used at all if frametype = -1, can't we just pass src = NULL to apiG729Decode()?
Same for g.723.
Vyacheslav_Baranniko
New Contributor II
Thank you for pointing this out.
Though 'Losframe' zero padded arraysize was alreadyoptimized in IPP 5.3 for some codecs evidently it was overlooked somewhere. NULL also possible to utilize in many cases.
WBR, Vyacheslav
IPP speech
