6825 Discussions
g729A and g729 sounds like howling (VAD disabled)
deepak_shenoy
I am not doing the bit packing as I am sending it to RTP directly.
I checked a previous thread where somebody seemed to have a similar problem when VAD enabled..But I made sure VAD is not enabled.
Rename the .txt as .pcm to listen to the voice
deepak_shenoy
Never Mind..It is fixed..I was not doing Init correctly.
Vladimir_Dudnik
Great, I'm glad you solved your issue
Vladimir
