h.264 stream decoding problem
Yaroslav_Korchevsky
IPP h264 decoder doesn't return decompressed image from the queue
returns UMC_ERR_NOT_ENOUGH_DATA instead
VideoLANs VLC decompresses it successfully
Yaroslav_Korchevsky
Here is the file grabbed from IP camera
pvonkaenel
New Contributor III
Quoting - jslav
Depending on what your code looks like, you might need to loop over the decode. If you have not tried it yet, load the file into the simple_player application. I always use that application for initial testing since it seems to be fairly compelete.
There is a good sample H.264 decode loop at the following link:
http://software.intel.com/en-us/articles/getting-started-with-intel-ipp-unified-media-classes-sample/
Peter
Yaroslav_Korchevsky
Quoting - pvonkaenel
Peter
Thank you for advice.
Yaroslav_Korchevsky
Quoting - jslav
Finally, I fixed my problem. It was the bug in my code of stream initialization method.
Thank a lot for reference.
ole_van_off
Had a similar problem with the live RTSP/RTP stream - finally got it working, but with resolutions bigger than CIF the decoder gives me UMC_ERR_NOT_ENOUGH_DATA for the *regular* GetFrame and UMC_ERR_INVALID_STREAM for the GetFrame with NULL for the in parameter...my packetization-mode = 1 and all NALUs are of types 5 and 1, and i feed them one-by-one...
could anybody suggest where to look for insight?
thank you,
Oleg
